84 Bayliner with Volvo 270 outdrive
jnorris1
Hello all,
I have a 84 Bayliner Capri, i believe it is a 1950, my question is after reading the adults only section, is there a easier way to change the drive bellow or is it pretty much how the manual shows? I'm not the best mechanic, but i do want to learn and try this on my own.(i hope..lol) any input would be great. thanks again
Don S
Re: 84 Bayliner with Volvo 270 outdrive
You do not have to remove the complete outdrive. Only the upper gear box.
http://forums.iboats.com/showthread.php?t=309095
The above link came from the Adults only section under Volvo information.
3. Replacing bellows on 250 thru DP-E outdrives without removing outdrive
jnorris1
Wow! (not as bad as i thought) Thanks for the information. If the weather will cooperate here in Indiana, i should be on the water in no time. Thanks again.
