84 70hp Johnson destroys plastic key. 3 times.
dlr441
Installed new impeller (twice) with new key. After idling for a very short time no water being pumped. Disassemble and find same problem-key rubbed bad enough to stop pump from turning with shaft. Could shaft be worn enough that the key won't lock up? Doesn't look bad, but I am not gonna put more parts on at this time. There has to be a reason; I just can't find it. Any help is appreciated.
Honorary Supreme Mariner
Never heard of that problem.------I believe there are 2 different keys and are you using the correct one ?---Perhaps the lower unit is not from an original 84 model, it may have been replaced .
boobie
Are you installing the key correctly. It only goes one way ??
dlr441
I did (surprisingly) think that perhaps the unit had been changed. A retired marina engine mechanic actually has done the work. I think he should Really retire.:blue:
There was a white key for earlier models and a black for later. We used the white as it is an 84 engine. I have been told that the shaft might be worn which allows some slippage and thus wobbles out the key. I really appreciate the rapid and intelligent replies and will post if a successful fix. Thanks and any further ideas are exrtemely welcome. Going out and tear it down me ownself this time.
Bosunsmate
shaft wont be worn there only where the seals rub above and below that area will there be any wearing
glust
I agree, There is no way a plastic key can hog out a steel shaft. I have seen woodruff keys hog out a crank before but they are both steel and the keys are darn near as hard of steel as the crank. Got to be the wrong shaft, the wrong key, or the wrong impeller. Are there part numbers on the shaft that can help you to know if it is the original? Could someone fabricate a steel key? I realize that's a stretch..
Sounds like you do not have the original unit.----Get the correct key in there.---No point in shimming the key either.----Post pictures with a tape measure to show the width of the flat.---Post pictures / part # of the impeller you are installing.
dlr441
Thank you all for the great answers. I do have the original lower unit, the shaft is fine, Nothing else seems totally wrong except the whole shebang is worn out. I ordered a complete water pump rebuild kit fm a place in MI today and it will replace all the grunged up parts. I think my real problem was the mechanic? who worked on the engine (note the total lack of cleaning of anything). I took it apart myself and was shocked: I would have cleaned. Now, can anyone tell me what the tube (circled in red) is? I cleaned a handful of crud (oily) from it. I would like to spray engine degreaser all over this and the top part of the lower unit and wash before putting the new stuff in and putting the unit back together. Degreaser, gasoline, which is the best. I prefer degreaser and spray the gunk away with water. Any thoughts? Thanks again to all. Will post whether it runs properly when finished.
dlr441
BTW, that impeller was brand new (fm West Marine) last Friday, 3/13. Oh heck, that is the problem? :eek:
Vic.S
that impeller looks as though its been run dry.
Are you sure its the right one even?
Did you have the right key for the impeller.I've had metal keys ( OEM) and plastic keys (aftermarket) The impeller key ways were different.
dlr441
The gentleman from whom I ordered the new kit said it is the same one he uses in rebuilding all kinds of lower units and guarantees it is the proper kit. Thus, the impeller and key are correct. Rather nice fellow and seems trustworthy. I shall assume that the new parts will handle the situation. I had previously verified that the lower unit is the original. That was not easy to do, BTW. Once I get the unit properly cleaned and put in all the new parts (even includes new bolts and such. New housing, o-rings and gasket) I believe my problem will be gone. I do agree that it looks like the impeller was tun dry. As it was installed Fri. the 13th and yesterday was the first time I started the engine, then I must have done the damage. I was using one of the muff style water providers. For my last boat, several years ago I had a much nicer rubber wrap around that fastened with velcro and had very little leakage. I can no longer find that type. Anyone know where I can get a better flusher? Don't much care for the muffs. Thanks
dlr441
reply to boobie. If that is the water tube then it is no wonder the water isn't moving correctly. Did you see the condition of the end of the tube? I wonder how to replace it.
Bosunsmate
The ex impeller gunk up there causes an issue too. Not sure you can backflush on that motor. Get as much out of there as you can and then run a hose on to it and check you get good water flow through the outets.
The tube isnt too bad. The rubber sleeve on the waterpump will move up it a few centimetres so so long as its alright above the bottom i wouldnt be too concerned about that bottom section but you could tidy it up a bit.
CHanging that tube requires lifting off the powerheah
boobie
You may have to pull the power head to replace it as there is a seal on top of it, but I'm not sure. I'm sure somebody else will chime in.
