The gentleman from whom I ordered the new kit said it is the same one he uses in rebuilding all kinds of lower units and guarantees it is the proper kit. Thus, the impeller and key are correct. Rather nice fellow and seems trustworthy. I shall assume that the new parts will handle the situation. I had previously verified that the lower unit is the original. That was not easy to do, BTW. Once I get the unit properly cleaned and put in all the new parts (even includes new bolts and such. New housing, o-rings and gasket) I believe my problem will be gone. I do agree that it looks like the impeller was tun dry. As it was installed Fri. the 13th and yesterday was the first time I started the engine, then I must have done the damage. I was using one of the muff style water providers. For my last boat, several years ago I had a much nicer rubber wrap around that fastened with velcro and had very little leakage. I can no longer find that type. Anyone know where I can get a better flusher? Don't much care for the muffs. Thanks
