83 Evinrude bogs and stops at idle and full throt
6whit
I have a 1983 50 hp Evinrude that seems to be getting too much gas and bogsdown/stops running. When i start the motor after this happens there is gas/oil in the water. The motor ran fine 1st day out but started having this problem after that. Thanks for any help Chris
fireman57
Re: 83 Evinrude bogs and stops at idle and full throt
Sounds like it's time to rebuild carbs. Probably just a stuck float but while it is off might as well spend 20 bucks and put a kit in them. Make sure that you blow all the jets out with an air compressor.
Richard Petersen
Varnished old cork floats are sinkers after a while.-------Some of the foams gain weight also.
