imported_beck
- Jul 7, 2006
- 56
Hi to all,
Replaced water pump and stat on '81 70hp Johnson. Test run it and when engine started pee ing fine would run it wot for a while then when I shut down and was idling no pee ing?? I still had water spitting/coming out of exhaust and I felt the engine and it didn't feel hot. I then shut the engine off and checked the pee tube and end fitting all clear. I start the engine again and it was pee ing run it for a while and again it stop coming out the pee hole?? Again water was comming out of the top exhaust and engine didn't feel hot you could put hand on block for a short while. I again dissembled the indicator tube and didn't find any blockage and when I started the engine it pee ok?? I didn't run too much longer as it was getting late.
Any input would be appreciated.
