807264A01 ICM Conversion wire colors
subysti
OK I'm installing this conversion in my 96 5.7L TB5. All the colors seem to line up except the last one. The color on the wire harness is tan/blu and the wire in the new ICM is white. I just want to make sure these connect to each other as the white wire has a female connector while the others are male. I looked up the wire diagrams and one has this wire as tan and another has it as Tan/Blu. Anyone else run in to this?
Re: 807264A01 ICM Conversion wire colors
Ayuh,..... 'n What conversion is That,..??
subysti
Ignition control module conversion from the OEM 807264T3 module to the new 807264A01 Module.
subysti
OK I cleaned all the wires to confirm their colors and the last wire not used is white with a green stripe and according to the prints is the shift cut out. So my question is does the last all white wire not used from the new module connect to this? Just want to confirm before I fry something. thanks.
subysti
Anyone? No one?
