80 hp 1988 no get up and go
reganjr
when going from idle to full throttle it takes 30 seconds for engine to respond (rpm).new filters installed and new fuel .new plugs
tashasdaddy
Re: 80 hp 1988 no get up and go
when you say respond, does it just idle and all of a sudden take off. not very clear description.
danielclubs
I have an '86 70 HP Merc and it is often a bit hesitant to "get up and go." Not 30 seconds, but a few at most. I did run a can of Sea Foam with about 4 gallons of premium gasoline a few weeks ago and ran it wide open for a little while. It really seemed to make a difference. This past weekend, however, it started doing the same thing although not quite as bad as before. I guess I'll try another can and see what happens.
PuckHog
Had the same issue of no hole shot with a '78 800 (80 hp) even after a carb cleaning and fuel pump rebuild. At the suggestions of the experts here at iboats, I re-cleaned everything and checked my float adjustment (both were off 1/8") followed by Clams' "link and sync" (not sure how much I like 'sync' in a sentence about boats...). Problem promptly went away. First hole shot almost threw me out of my seat!
reganjr
the engine rpm increase 's a small amount when I go to wot then 30 30 seconds the rpm builds suddenly to a wot rpm .then the engine runs normal till I slow it down or go to an idle, then the problems starts again .
tashasdaddy
i think puckhog is on the right track. linc n sinc, carb cleaning and rebuild are in you future. go to engine faq forum and read up on them.
MortenH
I also think that you should check the primer bulb and fuel line.
-M-
