8.1GI-a audible alarm issue
huisk
Hello everyone. This is my first post and I appreciate any help I could get to try to resolve my alarm problem.
i have a 2001 VP 8.1GI-a with about 420 hours on it. She run fantastic; water temperature heats up to 175 and stays steady. and oil pressure is consistent at 40psi. The engine does not go into limp mode.
Initially, I would get an audible alarm sounding inconsistently. I could shut the engine off and restart and alarm would go away. Recently the alarm became consistent from the time the motor was started until key was turn off. I can run the boat with no issues other than the annoying beep. I have been unsuccessful identifying the problem. I even brought it to an mechanic to have the ECM scanned and he came back and said it could be a Crank Position Sensor or a Cam Position Sensor. From my research I thought the only reason the alarm would sound is due to excessive engine heat or low oil pressure? I identified the location of the oil pressure switch (lower port side of motor with 1 electrical spade connector) and the water temperature switch (front starboard side near oil dipstick with a 2 wire connector). When I turn the key to the "run" position the engine sounds the usual 2 beeps. I start the motor and a loud consistant beep starts and does not stop until the engine is turned off. I have tried disconnecting each of the switches mentioned above and it does not stop or alter the beeping. If one of the switches is bad and disconnected will the alarm stop sounding? Are there other sensors the will cause the alarm to sound? Is there a procedure to test the sensor? What is the chance the ECU has failed? I would think if the crank or cam position sensors were bad the engine would run well.
Does anyone have experience with this problem and resolving it that can help out. Thanks again for any input!
alldodge
From my VP manual I'm seeing 3 items for a solid alarm
Low oil pressure
Exhaust Temp High
Engine coolant temp high (Port and starboard)
All the alarm switches have one terminal on them except the coolant temp, it has two
Note this is a MEFI 4
If you have a 555 ECM there could be more
huisk
Thank you for the response AllDodge, I really appreciate it. My engine is the "a" or first 8.1gi motor. It looks like the exhaust riser sensor want added until the "b" series of the motor. Also, my audible horn I refer to is mounted on the top, back of the engine.
Looking at the the diagram you attached I see the oil switch is an on/off switch and the temperature sensor has different symbol. Do you know the type of switch that is/how it functions and is there a way of testing it? If it was the culprit and I disconnected it should the beeping stop?
Thanks again!
huisk
Got it, thanks. I think I'm going to replace the ECT and see if that is the problem.
Silverbullet555
I have a 2002 8.1 gi-b so it might be different a couple years ago I got a constant beep. It turns out I had a broken wire to the plug on the back of the flame arrestor. Might check to see if you have that plug and if one of the wires is broken.
I'm surprised the tech couldn't give you more info.
