79 mercury outboard 90 hp (no spark)
shadow33
i have 12 volts at each coil pack while cranking but no spark. anyone have a sugustion?
OldMercsRule
Re: 79 mercury outboard 90 hp (no spark)
You need to follow the trouble shoot proceedure to check out yer switchboxes as It sounds like the stator is OK but that needs to be verified in the troubleshoot proceedure as well, (search the threads here or check yer engine manual).
I would also verify that you have the engine properly gounded.
Good Luck, JR
Laddies
Banned
Thats not nearly enough to fire a CD coil (transformer) here the system test.
