FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
working on a 1979 evinrude 15hp motor. has been running good. all of a sudden it will not shift in to forward. reverse works just fine. had to run 2 miles in reverse to get home.
Did you by any chance try to drain/change lower unit gear oil & may have taken out the wrong screw? If so this Phillips head screw is the shifter yoke pivot screw, & could be your cause if you did not get it back in right.
