This is my first boat and ive never done anything like this before but heres what im running into:
1 The deck was rotten working my way back and im about 3/4 of the way down the boat.
2 the stringers seem ok but I dont really know i havent drilled them or anything but as u can see in the pics the glass has separated and water has gotten in between. When i remove the glass the wood dries pretty quick but on some of the edges u can see the wood has splintered off. I have just been puling the splinters off as I see them.
3 The foam inside is very wet I have been pulling out as I go and most is soaked especially next to the stringers and hull.
I would like some insight on how concerned I should be about the splintered wood. Since I will have everything pulled out, should I go ahead and replace the stringers even if they are salvageable?
