78 Johnson tach not working
28sstony
I put a new tach and rectifier on my 78/150hp roughly 50 hours ago when I first rigged the boat. The tach originally worked after the boat ran for about 20 minutes. Now the needle will jump a little when the engine first fires but then drops back to zero. So basically its not working at all besides the ocassional needle jump when the engine very first fires.
What do I need to be looking at?
ezeke
Re: 78 Johnson tach not working
Run a temporary wire to the gray wire at the terminal block on the engine and back to the S post on the tach. If it works the wiring is likely damaged or your ground is weak. If there is no change, test the rectifier.
It takes very little to damage one or more diodes in the rectifier; just a loose battery cable can do it. Anything that allows voltage to run the wrong way to a diode can burn a rectifier.
28sstony
How exactly do I test the rectifier with a meter?
The wiring is all fresh 50ish hrs ago.
