78 johnson Spark-Ignition system !Pics Added! troubleshoot help needed
mmawonder
Well my 25 hp 1978 johnson seahorse 25R78C is not starting, after cleaning, adjusting and rebuilding the carb, it made a couple attempts to start but thats about it. I just pulled the spark plugs out and grounded them to the case and pulled the cord and I have no spark on both spark plugs. Then I took the coils off and cleaned and sanded the contact points. Then I took the flywheel off to see if I can service the points, but to my suprise there are no points, there are 2 little plastic boxes that looks like electronic ignition. What should i do now, is there a way to test or service that ignition system? How can I locate the problem? I dont mind replacing most of the ignition system, if it is going to give me a nice hot spark.
o/b tech
Re: 78 johnson Ignition system troubleshoot help needed
First try disconnecting the push button shorting switch and check for spark again.
mmawonder
i just pulled the cap off and the shorting switch seems to be fine
o/b tech
The switch should be a sealed unit and clean inside. Try taking off the ground wire at the powerhead. Also check to make sure that the pack has a good ground and see if this helps.
mmawonder
I broke the plastic housing while taking the switch off, it was clean on the inside, the gorund wire seems to be going to a screw that holds one of the coils not to the power pack. The other wire however runs to the power pack i think. Here I took 2 pictures of the system. How can I test these components such as the two plastic boxes, coils and the power pack?
Top view under the flywheel
side view where the coils are
mmawonder
Re: 78 johnson Spark-Ignition system !Pics Added! troubleshoot help needed
dodgeramsst2003
Well I'm not 100% on these ignition systems, but if I remember right, the parts under the flywheel are just magnetic pickups. Its usually the powerpack that goes. I had my 78 15hp quit running while trolling last year. I took a chance and replaced the powerpack and its been running like a top since.
mmawonder
mmawonder
Well I solved my issue and thought I would update this thread. My problem was the wire that grounds the power pack was cut in half. I am assuming from rubbing on and off to the cover. I cleaned and reconnected the cable using butt connectors and now I have spark like I neved had before. When I do a spark testing you can hear the plugs clicking from 3 feet away. Anyhow, now my motor starts well and runs strong, I guess until something else fails.
