tidechaser 1
Thread starter- Joined
- Jan 29, 2012
- 62
this motor has not been run for a long time..cleaned carb,changed lower end fluid which showed it had turned nasty from water intrusion,rebuild water pump.
got it running with the ears on it and later noticed grey oily gunk on the ground. the oil had been just changed..it has not been in the water yet.
i did make a boo boo and revved it up for a bit in gear..i forgot i had it in gear..probably should not be working on it with a bad head cold.
i would think if it was a prop seal it would have leaked green oil..not grey.
is it possible that it is just unburned two stroke oil and i need to clean out the engine with an additive through the carb?
thanks for the help guys!
i have another issue i will post seperately.
