78 johnson 35hp short to long shaft conversion
lwood24
i have a 1978 johnson 35 hp outboard that is currently a short shaft and i am trying to turn it into a long shaft i couldnt find any kits for this year but my question is will a long shifting rod and drive shaft work off of a 1984 model johnson 35 hp?
restornator
Re: 78 johnson 35hp short to long shaft conversion
i believe the driveshaft will work but not the shift rod (in 1979 OMC moved the shift connector behind the water inlet screens on the lower unit). The shift linkages are completely different.
Now, you will also need a long shaft exhaust housing, as there are no extension kits. And if you just bolt up the exhaust housing and l/u from a 1984, you won't need to worry about the shift rod nor linkage.
lwood24
i have a long shft exhoust housing but its not an 84 model i im pretty sure its off of a 78 model as well im just searching around trying to find a drie shaft and shifting rod that is reasonably priced for a used one and would like to have the water tube included but i havent been succesfull nin even finding the shifter rod but i appreciate all your help
restornator
my only advice on the shift rod is to find an older extension connector. it looks like the brass shift rod connector but is about 6 inches long. you see them on ebay from time to time
lwood24
yeah im affraid i will not be able to find the lower shifting rod of the upper shift rod in the longer exoust housing is there any other shift rod out there that might work?
