'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
rcxdm40
Re: '78 Ebko Lebaron - Therapy
I need to build me of those fine lookin gantry's!
craigweaver
Holy carp Troop! I disappear for a month or so and you get into a world of health issues and boat issues! The inside deck looks awesome. I hope your delam issues end soon for you. It took me 2 days but I finally caught back up on your progress. She's gonna be better'n new by the time you're done.
Good luck with the surgery this week, get those stones taken care of!
I'm back and now I gotta go start catching up with you all again!
rcxdm40
trooper 82 how tall is your gantry 10' or 12'?
Trooper82
Thanks, I find them pretty handy...could have had a better design though....
I made them from 10' PT wood. height and width....4x4...wish I had 4x6's fpr the tops now...would have been stronger...
Long time no see bro...welcome back...working through both issues...should all turn out great...
Trooper82
Welcome to the Circus!!!
Ebko-Therapy is featured under the BIG Top!!!
Got a little over half the far side stripped tonight...the two largest areas...should be able to finish up tomorrow...
Happy Monday...Come on Humpday...and Beyond :)
sphelps
Hope everything goes well with the ks Troop.. Tarp looks great should give a little relief from the sun ..
rcxdm40
Ordered wood for gantrys, took your recommended suggestion and got 4x6 for the tops. I like the idea of shade with the added bonus of lifting
Trooper82
Boatnut74 made a gantry system I liked...depending on the size of your boat this might work for you....
Gantry
Trooper82
Got the rest of the far side stripped...ran out of stripper so cannot finsh the keel areas...but most likely will be grinding most of that away anyhow...
Looking for some advice on what needs to be done in a few areas...this is the lower right side of transom..a plate with some HW mounted to it was screwed in here...Looks like the glass has cracked...another question I had...the gray stuff is about 1/16" thick here...it is pretty much covering the whole boat so figured it was fairing material...I can leave the gray everywhere?
Here the gray stuff is much thinner...and you can see that it has cracked from the ladder mounting screws....
I've been using a scraper..and this is the only place where I chipped this strake?..it is red hard glasslike underneath..not resin like, but sheet glass hard and brittle...
The bow eye that was mounted from factory I supposed..the one that still had metal in these holes...still have not repaired it from the outside..also not the bondo type material..front keel is covered in this...I assume I take that all out, build up layers with CSM/1708 and then grind down and fair?
several places in the corners are like this...again same as above...grind it out..layer it up...smooth it down and fair?
See the red under the gray? that is what the stripe is made of at top of hull sides... hwich is why I asked did the gray need to be sanded down to this?
jbcurt00
Without getting to lay my hands on it, & see it up close & all at once, man, I'm be hesitant to even comment..... But I haven't in a bit, so hang on & here we go.....:eek:
Looks like you've got a whole lot going on, and although it 'seems' that it may have gotten a re-spray gelcoat at one time or another, I'd have thought that the interior, once stripped & bare glass, would have shown evidence of a 'reason' for a re-spray. It didn't seem to look that way. Have you looked up a '78 Ebko & seen what the original exterior gelcoat color(s) options were?
Maybe it was that metal flake brown and a past owner didn't like it......
I don't know why, no basis in factual reality, but:
Ebko sprayed the mold for the hull just like most did, right? Maybe they shot the outside gelcoat & then shot the strakes & hard edges w/ a harder, more chip resistant gel(?) or resin to decrease trailer rash along the strakes which would decrease the hull's performance :confused:??.... Maybe?
This pix:
Looks kind of like previous repair work, or re-work by Ebko before the original sale ???
BTW: Trooper, ya know you don't HAVE to do the entire hull bottom better then Ebko did originally...
And those guys weren't fighting stones :facepalm:
You & SP need a support group :p
Awesome work, stones or no stones! And w/ stones, I can't think of a better descriptor. So I'll have to substitute size for substance:
AWESOME WORK!!!!!!!
John out................
Woodonglass
Troop as long as the "Gray" filler is bonded well and not flaking or peeling then sand and feather. You're "spot on" on the repairs, if it's not deep then CSM is good if deep then add a layer of 1708.
Trooper82
JB,
thanks man....I have seen other Ebko's of this make and near same year, they all looked the same.....brown paint over brown metal flake...then the red stripe with white everywhere else...doubt I can find anyone with knowledge if it was gel originally or not.....I have assumed all along it was white gel....but then hit it with stripper and it bubbled right up....gel wouldn't do that.
That first bottom repair I did was an area that looked like a fix from the inside to me...def some repairs there on the corners...
Hope I can get back at it hard this weekend!
Wood,
Thanks for looking in....i won't bother taking thos out then, just feather...some have gaps and cracks....getting closer to the end.......
Trooper82
No stent.....no stones.....no work on boat for a few days.......everything went well..... Thanks for thougts and prayers.....
Got pics but doubt anyone wants to see them...back to work on boat this weekend!
GT1000000
Glad to hear all went well and all of the offending matter is gone...now get some rest and recuperation...you'll be back at it in no time...
jbcurt00
In your stead, I'll see if I can conjure up some boat work gremlins to continue on w/ out you for a couple days!
Congrats on a successful resolution. NO PIX, please no pix........
Rest up!
Upon closer inspection, the conjured gremlins were not such a good idea. Nasty buggers just ate one of my raccoon posse members :facepalm:
Have a good couple of days recuperating... As if sitting & waiting a whole couple of days was possible....
Trooper82
Thanks brothers...I forgot the most important part......my dram cups are all to the point thatI can't read the numbers.....been looking to get replacements local, haven't had any luck....just prior to surgery theyhad me take a pill....and it was handed to me ina dram cup.....I said, hey I'll keepthat if you don't mind...ended up getting three total....score!
Could have ordered somebut who needs 100 of them?
Woodonglass
Have you check at the loca Rx store for the cups??
