78 115 help with terminal block connections please
jvr440
Hi,<br /><br />78 Johnson 115, model #115ETL78C. My terminal block has 2 wires on it that aren't connected to any others so I'd like to verify that everything is wired the way it's supposed to if someone can help. I have a service manual that covers multiple years, it shows terminal blocks from earlier years but not mine. I'm trying to diagnose an inoperative tach if you can tell me which one is the tach feed also. From top to bottom here's how mine is wired:<br /><br />1. yellow from wiring harness connected to yellow from rectifier<br /><br />2. yellow/gr tracer from wiring harness connected to yellow from rectifier<br /><br />3. brown (I think, hard to tell color) not connected to anything.<br /><br />4. red from wiring harness connected to red from rectifier<br /><br />5. darker colored wire (hard to tell color on these old wires) not connected to anything. This wire is +12V with key on.<br /><br />The wires on terminals 1+2 go into wiring harness with the 2 wires that feed powerpack, the other 3 go into a separate part of harness.<br /><br />Thank you!<br />Joe
rpv78
Re: 78 115 help with terminal block connections please
I checked my manual for ya,(I've got the same motor),and yes, that how its wired.<br />I'm kinda new at this so maybe someone else will be along to help you with the tach problem.<br />BTW, if its any help to you, the wire colors are:<br />1: yellow<br />2:yellow/gray<br />3:gray<br />4:red<br />5:purple<br />(I know what you mean about old wire colors!)
rpv78
And there's a metal jumper between 2 and 3.
jvr440
Thank you, I have the metal jumper too but didn't see it until now. So I guess it's wired ok. I think the gray wire is tach so I'll check the contacts across the jumper and check continuity up to the tach.<br /><br />Joe
