Re: 76 murcury 850 outboard wont shut down
Yes, if that motor is a '76, it will have four ign coils. The ign on that motor is killed by grounding the orange wire. You should see the orange wire on the switchbox. Put a meter on it (ign key off) and see if it is grounded. If not, trace it back to the ign key and see why. The ign key should connect it to ground. Some of the reasons that are possible is ground wire broke before key; key switch defective; orange wire broke before switchbox; quick disconnect plug bad.
