gonefishy
Thread starter- Joined
- Apr 30, 2012
- 20
Part of the Mercury trouble shooting manual states "Check the DVA output on the green wires from the switch box while connected to the ignition coils. Check the reading on the switch box and on the ignition coil terminal. You should have a reading of 150V or more at both terminals." I checked from the 4 green wires to ground and didn't get any reading which is odd because the motor starts and runs. The DVA readings from the stator and trigger coils were ok even though the resistance of the high speed coil was half of what is supposed to be. I am using a Fluke 87 on 120ms max reading scale. The problem with the motor is when cold it doesn't have full power, 22mph but after a minutes running WOT it kicks in another cylinder and ups to 29mph and is fine for the rest of the day and it always starts immediately. Can't figure why I can't get a reading from the coil primaries, any suggestions?
The manual also states if the reading is low disconnect green wire from coil and connect load resistor (doesn't say what size) and retest if ok bad coil if low bad power pak. The coils check out resistance wise and the motor runs so I think coils are ok. I need to figure out why I can't read the output from the switch to determine if it is bad.
