76 Holiday 18 ob restore with issues
alwaysaluminum
First off thanks for all the great info provided by those who boldly go where I would never go without seeing it done by someone else first. Here is my current project a 76 Holiday that I would love to make into a Holisport but have only seen one on here that was finished. Any input would be appreciated. Hopefully the pics show for the mob 😧
GA_Boater
No pics, AA.
You should be able to click on the IMG code box in PB and paste the IMG code inside a message.
alwaysaluminum
No Title
Well trying this and will try pb later
alwaysaluminum
More
Original Starcraft factory on the splash well
The flip and many thanks to Dozer and Inmotion for the paint stripping ideas. I snuck across the border and brought the Safe Strip back in a hockey bag 😉
GA_Boater
Oh boy - You got a note from #3 in the factory. And duffle bag sneakin', too. LOL
What is the plan after paint stripping?
jbcurt00
All looks great, good luck
The notes from the factory is a nice find.
Our operatives will be by to borrow that hockey bag ;)
There is no secret handshake :watermelon:
will w.
Love the way these old starcraft hulls are built. I picked up a 77 holiday last week, the difference in splash pans between your 76 and my 77 are just crazy. Good luck with you rig!
alwaysaluminum
So paint is stripped mostly thanks to the plastic covered strip then pressure wash approach. No fingernails were harmed but it did take 3 4-liter judges to finish it up.
I would love to polish and just paint the top similar to the latest Glencrafts but do run some salt for crabbing. Most of my fishing is in rivers so no paint means no scratches which would be great. Any ideas/input would be great.
alwaysaluminum
Ok need some help now because I am stuck. After the paint was stripped I found more pitting than I thought would be there and one hole from a bad roller trailer (really thinking of a bunk conversion). What do I do when there is pitting near the rivets?
And the hole that is clean through
Stupid rollers 😡
classiccat
"Captain" + Starmada Splash Of The Year 2020
Welcome to the Starmada AA! :welcome: Cool Handle! :cool:
With this many pics right out of the chute...your 1st year dues are paid in full. :D
inspect closely around where those rollers distorted your hull & look for stress cracks.
I can empathize with your corrosion issues...I have one of the holiest SuperSports on the planet :eek:
Now would be a good time to do a leak check...these are the obvious problems; a leak check should uncover other hidden obstacles.
For through-hull corrosion, I'd recommend cleaning the area really welI & apply an external aluminum patch buttered with 5200 with at least 4 solid rivets in that patch.
For the rivets, I would do something similar...apply an external patch and add additional rivets to secure it.
Unfortunately with external patches (aka, battle scars!), you won't exactly have the "GlenCraft" look...but they definitely add character to your craft!
jbcurt00
Classic didnt mention it, but IIRC, he drilled out the affected rivets, and used that existing thru hole for 1 of the new rivets. Then drilled additional holes as necessary to secure the patch.
Google
Clecos
You're likely to need them and they will make aligning, drilling and riveting the patches much easier.
Clecos are what repair places use to align panels. Once you see them and some pix of them in use, if you've ever seen a car (custom or basic repairs) get worked over in a shop, you'll recognize them.
W all that corrosion, I'd be surprised if you dont find at least 1 stress cracked rib end or a hairline hull crack radiating out from a rivet or 2.
GA_Boater
AA - The hole can be patched like the guys said.
On the corrosion around the rivet heads - How many are like that?
alwaysaluminum
Thanks Cat, JB, and GA (working on the quote thing) there are about 10-12 rivets with that kind of corrosion and there don't appear to be any obvious stress cracks but will keep looking. I went through Cat's saving a hull from death posts and the clecos seem like a good idea especially for the through hull patch. I am wondering about drilling out the bad rivets and replacing with larger heads and 5200.
dozerII
Just got back from Holidays and playing catch up. Great Holiday you found aa. The splash well in yours is the same as my 18 V5. Too bad about the corrosion issues, but they are repairable, but also means polishing may not be an option. I will be following along.
