dragginfly
Thread starter- Joined
- Aug 28, 2009
- 1
#1 cylinder works great. Motor starts and runs on one, but #2 cylinder is intermittent and creates a choppy ride up to almost half power. I changed plugs, replaced #2 coil (old one failed ohmmeter test) with some improvement. Still not right. When I rewire the #2 power thru the #1 coil to #2 plug, I can get #2 cylinder to fire. Can't get #1 cylinder to work from new #2 coil though(?). I can't decide if I have a #2 ignition problem, fuel problem, or a compression problem. I disconnected the kill-switches and that didn't change anything. The #2 cylinder is trying hard to run but just can't do it. Is the timing off? I've been "wrap-around" starting the motor b/c my recoil spring was shot and I fear I pulled something out of alignment. Any ideas? Thanks.
