75 Trisonic trim not working
daniel240
I bought a 1975 trisonic this winter with a bad motor and replaced it this winter. I started it for the first time yesterday and afterwards I checked everything else to make sure it was working and I noticed the trim was not working. I could hear a motor running when I hit the switch but the outdrive did not move. The guy I bought it from said it all worked last time he used it. Its has two switches, one for trailor tilt, and one for trim, neither worked. Could I have possible dissconected something when pulling the old motor and installing the new one? Im pretty clueless as to what to check on this. Any help would be appreciated. Thanks!
rndn
Re: 75 Trisonic trim not working
You should only post in one forum. You placed this exact question in the General Boating/Outdoor Activities section.
tashasdaddy
i have no idea what a trisonic is, a brand of boat. need to know motor you are working with. sure you could have pulled something loose.
daniel240
Trisonic is a boat brand that they dont make anymore. The motor is a mercruiser 888 (ford 302).
