Re: 75 Johnson Stinger...Overhaul needed??
ok guys, got a timing light and a new theory.
i got the timing light and did a "link and sync". most everything was in spec. i had to adjust the cam roller slightly, it seemed to help but it was still missing.
now i take the timing light and just point it at the boat and watch the "spark" and i notice that it looks weak and its intermittent. (def intermittent!) so now i'm thinkin power pack or stator. but in the back of my mind i'm still thinking of that burned up wire on the rectifier. so i come home, do some research, and learn that a burned up rectifier can cause a miss!!
so now i'm thinkin that that has to be it.
so from my understanding, i need to unhook the leads from the rectifier coming from the timer base, and if the problem goes away, that it's a rectifier problem, but if not it stator.
am i on the right track here people?
