quackerkiller
Thread starter- Joined
- May 19, 2010
- 18
Lately my 75hp mariner (1989 or so) had a little trouble running at trolling speeds. It would run fine, then rpms go WAY down and I'd have to choke it or it would die. It usually started right up but sometimes would be a bit of a pain. Yesterday it was running pretty well at trolling speed but on the way into the landing at 3/4 to full throttle it idled way down and died. I pumped the primer, started it and took off... same thing happend in another hundred yards or so...repeat...repeat...I had a friend keep pumping the primer when it was about to die and that seemed to work enough to get it in. The trolling and dieing was tolerable but this dieing off at higher throttle is unacceptable. What do you guys diagnose? Fuel line issue? Filter? Pump? All help is greatly appreciated!
