75 Horse Mariner leaking from lower end
starkyb
My 75 horse Mariner is leaking what appears to be lower unit fluid from the water intake holes. Is there some kind of seal that just needs to be replaced or is it likely something more serious going on. Any suggestions out there?
emckelvy
Re: 75 Horse Mariner leaking from lower end
Usually a sign of leaking driveshaft oil seals. The gear oil will leak out into the water pump then finds its way out the intakes.
You can find a parts breakdown from one of these sites then order the appropriate seals, gaskets, etc:
www.boats.net
www.crowleymarine.com
www.mercruiserparts.com
Recommend you renew the impeller as well, while you have the lower unit down for repairs.
Note you'll also find parts here at the iBoats Store but no parts diagrams.
HTH..........ed
