'75 evinrude runs best at half choke?
smallieback
I wasn't ignoring any advice just trying to make everything clear. I tried removing the jet but the last guy tightened it down so much that the head broke off of it and I ended up having to drill it out....waiting on the new jet now. thanks again for all the help.
F_R
I noticed you said the "bleed" screw is twisted off. That isn't a bleed screw, it is a plug over the orifice plug cavity. Since it is twisted off, you obviously haven't cleaned the orifice plug. So, there ya go--that is the problem. It has to be absolutely CLEAN without a trace of dirt or varnish in it. But don't even think of reaming it out with drills, wires, etc. It is a precision hole, not to be modified.
smallieback
already drilled it out...had to get to the jet somehow. i ordered a new carb bowl and plug also, but thanks for the heads up. how do you remove brass bolts/screws that have their heads twisted off if you don't drill them out? just curious
F_R
If you are talking about the brass orifice plug, you are supposed to use the special screwdriver made for the job. It has parallel flats so it doesn't spread the slot and just make it tighter than ever. You mention drilling out broken screws. You wouldn't be able to count how many I've drilled out in my 24 years as an outboard tech in a salt water area.
lindy46
Did you install a carb rebuild kit or just clean the carb?
