'75 evinrude runs best at half choke?
smallieback
Just got my impeller up and going and had it in the bucket letting it run. I started messing around with the rich/lean mixture and found out that it runs best at half choke? any one have an idea of why it revs that way at half choke?
SparkieBoat
restricted fuel delivery, possibly clog in carb or fuel pump weak or fuel line sucking air or other fuel delivery issue
or intake leak
smallieback
Well im about to throw this thing in the river....took it and cleaned the carb like you all have suggested...had it out on the river and it ran for about twenty minutes then went back to running on FULL choke for about 5 mins then completely stopped running....I had fresh gas in it, twc-3 on a 50:1 mix...took it apart today and cleaned the carb again and again its not even starting....it has spark and the fuel is getting to the carb just not into the combustion chamber....I noticed today though that the head on the bleed screw on the bottom front has been twisted off so I cant bleed the air out of the system...would replacing this screw be meaningful?
boobie
Is the high speed jet in the float bowl clean. It's under that screw you say the head has been twisted off of.
smallieback
yea that's the round tubular jet that goes up in between the choke plate and throttle plate right?
smallieback
could you point it out? I cant find it
boobie
That's the high speed jet that controls all the fuel that goes through the carb. It has to be clean.
smallieback
Are you sure that's a high speed jet? the breakdown shows that #12 is a high speed nozzle.....
SparkieBoat
also you should test your fuel pump and maybe buy a new fuel hose connectors/check fuel lines for dry rot cracking. , they are known to suck air and diminish fuel supply.
smallieback
I did some looking around looks like that #27 is listed as an orifice plug but then checked the 1976 model and its called the same thing but when I google that part number it comes up as an intermediate jet...
Honorary Supreme Mariner
Smallieback, are you aware that you are ignoring advice from people who have worked on these motors for more than 40 years !!!----Clean that orifice plug as the calibrated hole must be clean.--All the fuel for high and low speed running goes through the orifice plug !
