74? Glastron with 302 need fireing order
fireman24mn
I believe that it is around a 74 glastron V184 I can not get it to run right i think that I have the firing order wrong, A few of the cylinders at not firing. The firing order on the valve cover matches the firing order for a 351 but the valve cover says it is a 302. I have tried both the 351 firing order and the 302 firing order niether seems to be wright. is it different for the marine engine? it has a volvo outdrive Any help would be great thanks in advance
Capt Ken
Re: 74? Glastron with 302 need fireing order
The firing order is the for the 351. Due to the cam being a 351 cam, it follows that order. It should be a Mercruiser 188 but this is all true unless someone has changed out the engine to a non marine engine and its a true 302. Then it would be the 302 firing order.
