While cleaning up the carbs I noticed one of my carbs looked a little different inside the Venturi tube. There are three tiny little holes right at the butterfly on two of the carbs. The third carb carb has three as well only the third hole is about twice possibly three times the diameter of the other two holes. I just got this motor and it idles rough and reving it never smooths out. I put a timing light on it and it appears to me that the ignition is firing on all three cylinders. Is this carb causing the issues? Is there a fix for the carb or just replacement? Thanks for the help!
