74' 70hp Running Rough
Tjets
While cleaning up the carbs I noticed one of my carbs looked a little different inside the Venturi tube. There are three tiny little holes right at the butterfly on two of the carbs. The third carb carb has three as well only the third hole is about twice possibly three times the diameter of the other two holes. I just got this motor and it idles rough and reving it never smooths out. I put a timing light on it and it appears to me that the ignition is firing on all three cylinders. Is this carb causing the issues? Is there a fix for the carb or just replacement? Thanks for the help!
titaniumneck
My best guess is someone drilled that hole bigger for better airflow at idle. Half ass way of doing it the wrong way, shortcut to bypass having to rebuild carburetor right. So now if someone went and cleaned and rebuilt carburetors right, then this bored out hole is going to make it idle rough. Fill in hole with j.b weld puddy, then drill it to right size. If that works, I would replace that valve.
jimmbo
It's possible either one or two of the carbs were replaced. Carefully compare the oddball carb to the other two. Same size throttle bore? Jetting same? Any differences, other than linkages attached?
Honorary Supreme Mariner
I assume the hole is drilled in the carburetor body.------Sounds like a mistake when removing welsh plug.------Fill with JB weld and drill proper size.---------Do a compression test and a spark check on this motor.
Tjets
Thats right taking the welsh plug out is what I think too. Those holes are so tiny, any idea what number bit its going to take? What would be the result of leaving that damaged hole plugged with JB weld and not drilling it back out? Any thoughts? I when ahead and put a tiny dab of JB from inside the hole the welsh plug covers. I spead it out over the surface of the dinged up hole careful not to cover the other two. Also put tape on the other side so it would be flush. Removed the tape today and all looks good read to drill but wondering where I'm gonna find a drill bit that small. Tempted to plug it and try running it but don't want to do any damage to the engine creating a lean condition for that cyl.
Lean condition at idle likely will not do any damage to the engine.-----That is a full throttle problem.
Tjets
I think I might just try it with that hole plugged. I'm at roughly 900 to 1000 msl. It may run fine, who knows, may not need that extra fuel unless maybe those are for mid range. I've also discovered another problem was a leaking fuel bulb full of old nasty sludge, caused me to have to clean the carbs a second time but I'm learning and slowly getting closer to hopefully a smooth running classic. :)
