HPTGreyGhost
Thread starter- Joined
- Jul 17, 2010
- 42
I have a 1974 volvo penta aq240 (Ford 351) mated to a 270 outdrive. I found a complete '97 vp 5.0Fi (Ford 302) that was mated to an SX. Compression isn't great on my old 351(some cylinders have 200psi, some have 140psi), and I'd like to put in the newer EFI engine instead. The motor mounts look to be in the same location. I've pulled my 351 twice since I've owned it so I understand how that goes down. Is it as simple as pulling the 351, swapping out the bell housings and drive shaft or will i run into some trouble with flywheels or bolt holes not lining up? Thanks.
Attached is an image of when we pulled the 351 for its rebuild. (Note: Strapping an engine hoist to the tailgate of your F250 is not recommended for engine removal... but sometimes there isn't another option.)
Hoping to use this 302:
