73 Evinrude 115 - Lower End - Correct Sealant to use
BOAH
In my manual it says that when replacing the shaft seals to wipe the outer diameter of the new seal with OMC Gasket Sealing Compound.
I've got a gasket seal that I've used on other stuff that I'm wondering if it would be OK to use in this application. It is a Permatex Gasket Maker, Ultra Black OEM Hi-Temp RTV Silicone.
Thanks!
