Re: '72 Johnson 50 HP...carb cleaning.
bump
I know my high speed jets are located on the carb bowl drain plug, but where are my idle speed jets? Do I remove the small brass cylinder that extends into the venturi of the carb or just spray and blow in it? What about the idle adjustment screws, found out thiese are needles when you unscrew them all the way out...what do I do with these to clean?
bump
