Captain Caveman
Thread starter- Joined
- Mar 1, 2005
- 1,059
I've got a 16' Fisher boat with my 25hp Evinrude. When boating around at WOT, a tremendous amount of water splashes up from around the motor shaft and either straight up or against the boat.<br /><br />I shimmed the motor, adding about an inch of wood underneath the mount to raise the entire motor higher. This has helped a bit. Adjusting the trim has also helped out a little.<br /><br />Has anyone else experienced this? What causes it? What is the solution?<br /><br />I assume that this backsplash and spray is slowing down my top speed.<br /><br />Thanks.
