'72 65hp Johnson lift ring
Chaz1
Heys folks, quick question. My transom is in need of replacing and I'm wondering if I can pull my motor off using the cylinder lift ring on top of the motor. Or is that used just for pulling the cylinder block off? Thanks in advance for any helpful hints.
tashasdaddy
Re: '72 65hp Johnson lift ring
if you have a lift ring use it. that is what it is for.
Chaz1
I have'nt been on here for quite a while but as usual Tashadaddy is as reliable as gravity!!! Thanks Tasha!;)
