DOES ANYONE KNOW WHERE I CAN BUY A SNAP RING PLIERS FOR THE PROP SHAFT LOWER UNIT? IT NEEDS TO BE A LONG NECK BECAUSE THE SNAP RING IS ABOUT 10 INCHES INSIDE THE LOWER UNIT OF MY 1971 50 HP OB EVINRUDE.
hi lake i had that to do on an eletric foot . couldnt find a tool to do it with. i had a pair of needlenose pliers ground the points to fit in hole they were to short to squeese with my hands so i used a pair of channellock pliers. it worked fine . just ues some enguinoty. papasage
Northern Hydrolic has some long neck snap ring pliers<br />which are long enough to pull the prop seal, but<br />not quite long enough for the oil pump should you<br />ever need to get that one out.
