robertshadow
- Mar 4, 2006
- 6
Idles ragged, sputters & speeds up intermittently. Compression 150lbs on all 3 cylinders per cheap compression gauage. Carbs just<br />cleaned & kits installed (improved idle concern,but didnt fix it). On the #1 cylinder I can disconnect the plug while running or close the idle needle & the sputter will go away. If I <br />disconnect plug on 2 or 3 or turn idle needle too far in out it will die. If it sits for week or <br />several days its hard to start like no fire. <br />My gut tells me its an ignition problem, as I could find no issues with carb. Also seems to drop<br />a cylinder intermittenly while cruising, again seems like loss of spark for a split second. Coil<br />housing is cracked, but I cant find any external<br />carbon tracking. Also I cant imagine that only <br />affect number one cylinder. I am considering removing flywheel & looking at distributer cap/spark distribution setup (havent had it apart<br />before). I am looking for tips on diagnostic steps<br />I might take before dig into it or what others have found to be root cause on similar problems.
