70HP Tilt/Trim
Fish Idaho
I have a 1993 60HP Evinrude with a bad powerhead..I have a line on a 1987 70HP Johnson, except the 70HP has no tilt/trim. My question is will the tilt/trim off the 60HP work on the 70HP??? Thanks, Alan
emdsapmgr
Re: 70HP Tilt/Trim
The trim systems are significantly different and may not bolt up. You may have to consider going a different direction. You might consider the possibility of swapping powerheads.
D
DJ
Guest
Re: 70HP Tilt/Trim
It will not swap. You must be looking at the '87' on ebay.
