70 Evinrude overheating w/new pump and thermostat
G
Guest
Guest
Hello All:
I'm on a fact finding mission here for two friends of mine who have the same outboard with the same problem.
Each one has a 70hp Evinrude,
one is a 1989 and the other one is a 1995.
Each owner replaced the water pump and thermostat in their respective motors. They get a steady stream of water out the telltale and two idle relief ports at the top of the motor leg. So the engines are pumping great.
Unfortunately, after they run these motors for a short, time they overheat,
The 1995 model goes into S.L.O.W mode.
The 1989 has a warning buzzer that goes off.
I thought this issue might be the heat sensors in the head, but they replaced those too.
These guys are stumped and I am too.
I'm sure this issue has come up before on this site, but if anyone has had this problem with this particular motor, I would appreciate some advice. My buddies are at their wits end.
Thank You!
sutor623
Those 3 cylinder 60's and 70's had service bulletins back in the early '90s to help overheating problems. Be sure to use the complete factory water pump kit as it is a high-flow design and comes with the fittings to reposition the water tell-tale from the side of the exhaust cover to the top of the exhaust area. That removes trapped air better and increases water pressure. A new thermostat relief spring is also included because of the higher water pressure.
sutor623
SB2276R1 dated April 1994 relocated tattle tail nipple from side of block to top of engine to vent air for better cooling at idle. Waterpump kit 432955 has SB 2276R1 in kit, a choice of 2 new pressure relief springs depending on model of engine with cover, and improved impeller.
flyingscott
Only the 1989 would need those updates are they salt water motors. Did they have the problem before they changed the impellers.
oldboat1
My first step is always to see if it's actually overheating, and see what the temp is. Get your buddies to go halvies on an IR temp sensor, and get surface temps on the tops of the heads. (140 to 160F is a normal range). Need to run them in the lake or a deep barrel -- muffs not good for this.
[ed. high throttle operation isn't necessary, and could be damaging if there is an overheat problem. Shut it down if measured temps exceed 160.]
G
Guest
Guest
Sutor - I have heard of the tell tale hose relocation, both of my buddies used genuine BRP pump kits and parts. Each kit was purchased for each motor using the respective model number. you mentioned (2) pressure relief springs with the kit, I wonder if they have the wrong one installed.
Scotti - Both engines run in brackish water. the 1989 overheated before the new pump impeller install, the 1995 ran fine.
Old boat - the owner of the 1995 did indeed get a temp sensor, and after she climbs above 160, she goes into S.L.O.W. and he shuts her down.
oldboat1
Hand held temp gun gets benchmark numbers for the engine, and does a basic test of the onboard sensors and warning systems. If indeed overheating, might remove t.stats and see if operating temps improve (function/installation of t.stats). With t.stats, covers and l.u. removed, can do a fresh water flush from top and bottom to see if the flow is correct (engine off), and possibly to clear out corrosion.
['95 installation invites reinspection, IMO, as the problem began after the work was done.]
juno pierrat
i did a search on "SB2276R1 dated April 1994" , some good info on site Continues wave, from 2011, a list of service bulletins , this may not apply to the 89' and may be good info for the 95',
flyingscott
If the 89 overheated did the impeller come apart if so were all the pieces found. On the 1995 model go back through it and see if the rubber grommet on the water pump housing was kinked.
oldboat1
on the tell tale relocation, wasn't there an option of rerouting the outlet line over the powerhead, then down and out on the starboard side? If accurate, that would be an easy (easier) fix, and simple enough to use temporarily for troubleshooting. Haven't tried it.
flyingscott
Yes you can run the line 0ver the top of the motor. Why are we fixated on moving the line. The 95 MODEL DOES NOT NEED THE TELL TALE MOVED. The 95 was fine until the pump was replaced. The 89 sounds like had a pump failure. These are not the same motors there was a block redesign in 1995 so these are 2 different motors. The telltale being moved is a service bulletin only for certain kinds of conditions.
oldboat1
Thanks for the clarification. But the water pump in the '89 has been replaced, and would not sound like pump failure. Blockage is not ruled out, but if running the tell tale line over the powerhead was indeed a relevant fix, it could be tried.
Capt. -- consider routing the tell tale over the head as described. Should be able to do that without much difficulty, and may make a difference if the service bulletin applies.
sutor623
Hard to say, but the relief spring has NOTHING to do at temperature at idle, just high pressure, high speed. Here is how my '84 had the hose routed. They ran it up and back down so that if there was any air in the water jacket it would go to the top of the hose instead of top of the block.
oldboat1
Capt. -- could be easy troubleshooting/fix for an airlock, seems to me (good pic, Sutor). May still have to get into the '89 for debris, but maybe not.
flyingscott
Post #6 specifically says the 1989 motor overheated before the water pump was replaced would like to know if the impeller was in pieces or not. Sutor your motor does not apply as the service bulletin was for 56 CID 1986 and later blocks only. Yours as an 84 is the 49 CID block did not need the updates as they did not have the problem. There are more to it than moving the hose the nipple outlet needs to be removed and the thermostat spring needs to be changed.
oldboat1
Capt., have your buddy check to see if the airlock fix applies, then try it -- above assistance appears to be available. Would still make sure an IR temp is taken, just to know what he has. Sutor.... good looking motor.
flyingscott
One other question is the vro hooked up and is it a constant warning horn for the 89 model. Now there are 15 posts about moving the indicator line on motors that have worked well for 20 plus years as they were.
oldboat1
mmm. 16 posts, I guess.
re. question as to which warning horn. Always check the surface temp of the head independently of onboard sensors or systems when thought to be overheating (both motors). Shut it down in response to any warning, known or unknown, and test the surface temp.
flyingscott
WHAT my question as to the warning horn is because there are 3 on a VRO motor is the OP sure it's the overheat buzzer. Would also like to know if the impeller was in one piece when it was removed from the 89 motor. The OP said it overheated prior to the pump replacement. The 95 you need to go back through and see what happened as you did not have the problem before pump replacement.
