G
Guest
Guest
Hello All:
I'm on a fact finding mission here for two friends of mine who have the same outboard with the same problem.
Each one has a 70hp Evinrude,
one is a 1989 and the other one is a 1995.
Each owner replaced the water pump and thermostat in their respective motors. They get a steady stream of water out the telltale and two idle relief ports at the top of the motor leg. So the engines are pumping great.
Unfortunately, after they run these motors for a short, time they overheat,
The 1995 model goes into S.L.O.W mode.
The 1989 has a warning buzzer that goes off.
I thought this issue might be the heat sensors in the head, but they replaced those too.
These guys are stumped and I am too.
I'm sure this issue has come up before on this site, but if anyone has had this problem with this particular motor, I would appreciate some advice. My buddies are at their wits end.
Thank You!
Thank You!
