70 Evinrude Issues
Matt_70
I need suggestions. I just bought a 15' bass boat with a 77 model 70hp Evinrude. I got it cheap and have had to do some obvious work to it so far to get to this point. Cylinders all check out about 105psi. I replaced all three coils and plugs. Also changed the fuel line from the tank to the motor. I replaced the impeller. First time I took the boat out, it ran fantastic. Started right up. Ran strong at full throttle. Never really tried to idle much, just started it and went. My second time out, the next day, it was very difficult to start. Would start but wouldn't idle. Acted completely different than the day before. After about 10 mins of fighting with it, it finally started and acted like it should. Idled out of the no wake and took off, all was good again in the world. I ran up the lake a mile or so and pulled up into a cove and idled around for two minutes or so. I went to take back off and the motor fell on its face and died. Would start back but would not run over 1/4 throttle. I tried to get it to clear up but it was acting flooded. After several minutes at 1/4 throttle I finally got it to clear up and run at wot again. I tried to idle it again, once i got into comfortable trolling distance of the ramp, and had the same result. I am assuming this is a carb issue but I was hoping to get opinions from someone much smarter than me, and I don't set the bar very high when concerning outboards. Thanks in advance.
DECK SWABBER 58
Definitely would disassemble all 3 carbs, soak in carb cleaner, one gallon can available at any auto parts store. Soak overnight then rinse with hot water and blow out all passages with compressed air. You will of course need carb kits, I'd also replace the floats, they usually come separately. Also make sure your fuel tank is clean and replace fuel filter/filters, not sure of their is more than one. More knowledgeable omc guys will chime in I'm sure but it does sound like a carb issue.
flyingscott
I would get a different gauge and recheck those compression #s. Do you have fresh fuel sounds like you may have water in it. Also check for spark.
oldboat1
also think you may have water in the fuel. Sample from the bottom of the tank (just use the primer bulb to draw some out), and let it settle in a clear jar. Fuel will float on top of any water.
Matt_70
Fuel is fresh. I checked for separation. I feel confident the fuel is fine. The only fuel filter I know of, I just added when I changed the fuel line. flyingscott Why do you think i should recheck compression? I don't mind doing it, I'm just trying to follow where you're going with this. Do you think those numbers were incorrect?
I've heard for years about all these guys running sea foam through various motors and even though I have always been super critical of the results, I have been somewhat contemplating trying that. Thoughts?
F_R
Buy some stock in the Sea Foam factory too. Whole lotta people spend money on the stuff.
Matt_70
I've been told anything over 100 and within 10% are fine. I have no idea. I am simply repeating what i was told.
