I need suggestions. I just bought a 15' bass boat with a 77 model 70hp Evinrude. I got it cheap and have had to do some obvious work to it so far to get to this point. Cylinders all check out about 105psi. I replaced all three coils and plugs. Also changed the fuel line from the tank to the motor. I replaced the impeller. First time I took the boat out, it ran fantastic. Started right up. Ran strong at full throttle. Never really tried to idle much, just started it and went. My second time out, the next day, it was very difficult to start. Would start but wouldn't idle. Acted completely different than the day before. After about 10 mins of fighting with it, it finally started and acted like it should. Idled out of the no wake and took off, all was good again in the world. I ran up the lake a mile or so and pulled up into a cove and idled around for two minutes or so. I went to take back off and the motor fell on its face and died. Would start back but would not run over 1/4 throttle. I tried to get it to clear up but it was acting flooded. After several minutes at 1/4 throttle I finally got it to clear up and run at wot again. I tried to idle it again, once i got into comfortable trolling distance of the ramp, and had the same result. I am assuming this is a carb issue but I was hoping to get opinions from someone much smarter than me, and I don't set the bar very high when concerning outboards. Thanks in advance.
