screaming voodoo
Thread starter- Joined
- Jun 15, 2008
- 17
Can I remove the 6 bolts holding the exhaust shaft to the power head with out messing anything up. My motor does not shift into gear and when I removed the lower unit the whole shift rod came out from the top. There was a washer with a cotter pin attached at the top of the rod. So I am sure something got jarred loose. I thought I could remove the bolts and take a look. I am hoping the only thing I need to be careful about is the gasket.
Thanks for the help
Thanks for the help
