6hp, 1974, removing shifter bushing in lower unit
scott_maier
Hello,
I'd like to remove and replace the bushing and oring for the shifter rod in the lower unit of my 1974 Johnson 6hp. I have a bad water leak into the gear case and I think the oring for the shifter rod is the problem. Do I need to make a special puller for this bushing or can i bump it out with the right sized rod from the back side?
Thanks in advance
AlTn
Re: 6hp, 1974, removing shifter bushing in lower unit
read the posts under Removal Tool For Shift Rod Bushing phoodieman was the op...it's currently on page 5
Tim Frank
Hello,
Thanks in advance
If you are going to replace the bushing you can tap it with a 5/16-18NC tap and use a bolt, a couple of nuts and a plate with a hole in it as a puller to pull it out.
scott_maier
thanks for the replies. I had searched the forum before posting, but hadn't found the above mentioned thread...
scott_maier
Thanks. Those pictures are great. Question...is that OMC sealing glue still available??
