JASinIL2006
- Feb 10, 2012
- 5,749
For grinding, I would probably grind just enough to get to good, clean glass. I don’t see the advantage in removing more material than you need to.
For OSB (assuming you mean OSB and not waferboard), what is the advantage? OSB takes on more damage when edges/holes get wet than does plywood, and it’s main strength advantage is in shear. When used in flooring, you generally need to use thicker sheets of OSB than plywood (3/4” vs. 5/8”) which means more weight. I don’t have anything against OSB, I just don’t think this is the best material for this application.
