HighTrim
- Jun 21, 2007
- 10,486
Re: 69 Evinrude How to replace coils,condensers,plugs ,and points
This is about the best article I have read on testing these old points and coils. Have a read, it will save you trouble shooting in the future.
http://www.pochefamily.org/outboard/Coils.htm
It will only cause problems if there is a short in the line somewhere, or the ends of the wire where the cut is is not 100% sealed up. While its apart I would personally run new wires, with proper length, that way if you do decide to put a kill button the wires are run and where they should be. All you need is a simple push button switch available almost anywhere for like 10 bucks. It is a very easy hookup.
