68' Johnson 20hp (FD 22M)..Want to add starter..
Status
Not open for further replies.
Roy Wirebaugh
Hi folks, I want to add a starter to my 68' 20hp johnson(FD 22M). It has the starter ring on the top already, but I cant find out what else I need. I have looked at both the BRP and boat.net parts diagrams and dont see the starter set up on either Can somebody let me know what I need?...Thanks, Roy
bonz_d
Re: 68' Johnson 20hp (FD 22M)..Want to add starter..
Short list; Starter, starter solenoid, wires, switch/button, battery, battery cables. Might take some searching to find a starter and solenoid.
Roy Wirebaugh
Thanks for the list. Do you know the part#'s or years of the starter and solenoid that will work on the motor? I have access to alot of old parts and need to know what to get.
bonz_d
Sorry, can't help with part #'s and you are correct in that it looks like BRP can't either. Not sure if the 25hp used the same starter.
F_R
Honorary Supreme Mariner
Roy, you have a PM (Private Message)
Roy Wirebaugh
F_R, Pm returned and email sent....Thanks, Roy
Noel Kinahan
Hi Roy,
I have a similar model and was thinking of doing the same. How did you get on , did you have any success in getting your parts?
Regards,
Noel
Wishiniwuzfishin
I recently went through the same thing when trying to add electric start to my 63 18HP. I wasn't concerned with finding a part number but I wanted to find a pic of someone that had the electric start set-up so I could see what I was looking for.
Made a post on here asking for a pic and had several replies.
http://forums.iboats.com/showthread.php?t=413566
I think it may be the same bracket you guys need but not positive. I believe the solenoids are almost all interchangeable. I think your best bet is to start a new post, ask for a pic of what you need and at least you will know what you are looking for.
Turns out I found a parts motor..25hp, can't even remember what year, on my local Craigslist. Since I now knew exactly what I needed, I went to look at it and it was the right bracket and solenoid. He wanted $150 for the motor but I talked him into selling me just the starter and solenoid and brackets for $50.
Took the brackets I had off, bolted on the new ones with the starter and solenoid and now just need to wire a switch too it.
Will Bark
My neighbor did practially the same thing except he did not even use the solinoid; just got a 60 amp switch button from Auto zone and wired straight from battery to the starter, button cost him about $10.00 bucks. Works for his just fine. Basically the same setup as on the 15HP Evinrude.
samo_ott
And if you will be using the engine remotely you will need the choke solenoid and wiring.
Status
