jhouser
Thread starter- Joined
- Apr 27, 2010
- 35
Forgive my ignorance on this please this is my first boat and it was given to me by a friend. I know a lot about a lot of things but motors and especially boat motors are not one of them. But I am good at fixing things around the house and yard and a lot of things.
It is a white and blue 1972 Mark Twain 16' with a 1967 Mercury 950SS Thunderbolt motor that is 95 hp. The motor looks great on the inside, he said it has been rebuilt within the last few years, and it did run great.
My friend took the boat out and I was on it a few times and it ran great, went quick and was powerful. He got a newer bigger boat so he gave me this one. It sat for a year and when I went to pick it up it would not start. It would crank over but would not spark. I asked my brother to help me, he thought it was the switch box cause he had a problem with his on his boat and he took it off, he put it back on after looking at it and looking for damage. We tried to start it again this spring and it still would not spark.
I towed it to my house and washed the boat cleaned it out, etc. I also went and bought a new battery, new fuel lines and new gas, and a new fuel filter. I have all of that installed and hooked up.
So here is the problem I am running into right now. I am trying to get the linkage completely hooked up for the shifting, but I have realized it has been in gear all of these times I have tried to start it, I have been around boats a little and knew the prop would spin just a little even when not in gear, like fluttering. So to see the prop spinning it did not occur to me that it was in GEAR. I have verified that it is in fact in gear, I know it is.
I have tried to push the shifter thing back that is in the motor (with the cover off) but it only will move back an inch and it will not click into neutral or reverse, it is stuck in forward. How can I get it to go into neutral when it is bound up? What can I do?
This is my first boat and I really want to get it running and in the water soon!
Thanks.
Josh
Thanks.
Josh
