Re: 66' starcraft sportsman
Here's may take on your boat:
Your transom, since you're removing your motor for paint there's no reason not to pull that transom wood. Motor removal is the hardest part of replacing a transom. It may look like a daunting task, but it isn't that bad.
Your transom hasn't been sealed properly and this is evident by the checking in the wood above the splashwell. Even though the side you can see doesn't look too bad, you don't know what the other side looks like and it'll be the first place rot starts.
Remove your transom wood and check it for rot and moisture, if it's good and dry you can sand it down properly and seal it and put it back.
While you have the transom wood out you need to check the inside of the transom skin (metal) that the wood was up against. If your transom wood is wet on the back there's a good chance you may have corrosive pitting (a common problem we see lots of in this forum) on your transom skin. If you have pitting it will need to be skimmed over with a marine epoxy like JB Weld Marine or Loc-tite Marine Epoxy and then painted. If there isn't any pitting you should just paint it. A coat of aluminum primer and then a couple coats of metal primer will protect it from pitting in the future.
Gluvit or Coat-it:
Clean and degrease the inside of your hull like you described and then follow the manufacturers prep instructions to the "T". There's prep instructions on the can.
Sealing your transom and deck wood (plywood):
I strongly suggest using 2 part marine epoxy resin for this, it's the toughest most durable sealer you can buy. Several coats of epoxy resin on your wood is like a sheet of Lexan over it, you don't need glass cloth or mat because the epoxy is strong enough by itself.
Durabak:
I like the idea of using Durabak on your decking and the exposed side of your transom. Apply it after you epoxy seal the wood and before installation of the decking and transom for a durable water shedding finish. Install your decking with exposed fasteners so you can remove it later if you need to without tearing up your deck or finish.
You also mentioned marine vinyl:
I did my boat with Nautolex marine vinyl and love it:
http://forums.iboats.com/boat-resto...ir/97-tracker-pro-deep-v-facelift-509163.html
It is considerably more costly and a lot more time consuming than the Durabak though.
You also mentioned the interior design of your boat:
I would enlarge the front deck and raise it up to about 6" below the gunwale.
I'd also move the console over tight to the starboard side for more room and better access to the front deck.
The bigger front deck will be nice for a pedestal seat and you can put in some hatch storage too.
