I replaced the fuel pump as, at that time it ran much better when pumping the primer bulb.
I removed and cleaned the carbs and noticed the floats were on an angle when inverted. Manual calls for 1/16" clearance and "parallell".
I checked and replaced a couple of fuel lines from pump to carbs; no leaks now.
I substituted a different tank and fuel line that worked on a 10 HP Johnson and the motor operated the same.
Compression; 135 PSI Top, 132 Mid, 132 lwr.
Idle mixture screw and seat looked good, high speed seat looked good (no high speed mix screw)
Question:
1. Could my problem be the floats not being set properly? As the floats were all angled, not parallel, is it actually possible to bend the metal arm and make the floats parallel?
2. Any other possibilities?
Thanks, Jerry
Question:
Thanks, Jerry
